lca's and al. driveshaft
Aluminum driveshaft from powerhouse plus lca's and brackets installed now. The black beast launches like a rocket.Waiting on the FAST intake to see what kind of h.p. it puts out. I really need to make up my mind on the Whipple or the Paxton from Brenspeed.
RE: lca's and al. driveshaft
I have both .. And im having a ****ty launch everytime ... either its my tires or the LCA'S needs to be adjusted...
there is a mini vibration when Im driving 80 and up .. especially when I hit 120 and leave the pedal the car vibrates and shakes like hell ... Im having a huge problem adjusting my LCA'S ... these shops act like asses .. they dont know how to adjust.. Im even planing to put back stock LCA'S and see if its stil there...
Do you have the BMR's or another brand? I have mine set in the bottom hole on the bracket. Also do you have an al. driveshaft? With the BMR's the offset is already in the control arm. I can't imagine them being able to install them incorrectly. But maybe they can. Crazy Al might be able to help you out, maybe its the pinion angle. What size tires do you have on your car and are they pretty worn? Also I would think you would be experiencing alot of fine dust on the roadways over there, which isn't conducive to good traction. The vibration is concerning to me, can't really say I'm experiencing any of the problems your having. Matter of fact, everything seems to be quiter and smoother as far as shifting, and drivetrain noise. Hop in here Al.
ORIGINAL: saud alzaabi
I tried taking it to a shop and they had this angle measurement tool, they placed it against the diff and did few tweaks here and there and set a -2 degree for it.. but the noise was still there.
I will try replacing the stock lowers back and see ...
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
