Hurst shifter...UPDATED PICS
RE: Hurst shifter
ORIGINAL: Johnnie D
damm i just got mine, i dont like the way the stock laether boot looks with the shifter, i was hoping to see more of the chrome [:'(]
BUT IT IS A NICE SHIFTER .
RE: Hurst shifter
Looks like somebody didn't get a shift boot adapter or didn't use it.
When I ordered my Hurst, it was missing the shift boot adapter. I called up Brenspeed, was here in two days.
-Jeff
-Jeff
RE: Hurst shifter...UPDATED PICS
Don't forget to use some blue Locktite on the handle screws. The handle WILL vibrate loose after some time.
Also I use the T-handle. Seems to help to ensure putting the handle in the right place when shifting. I also got a black ball 'cause the aluminum T is freezing in cold weather.
RE: Hurst shifter
ORIGINAL: Fireguy28
so this is just the regular hurst shifter...not the competition plus billet shifter right? And what is the real deal with the engineering hold?? Why is it taking so long???
RE: Hurst shifter
Stock **** won't fit on this Hurst shifter to answer someones question above.
The Hurst shifter is a little taller than the factory, i'm currently trying to find out if Hurst makes one shorter.
As far as the shifter itself, heads above factory and easy to install. Instuctions come with it, they say you need 2 people , you don't. The only thing I'd say is when you get the factory shifter out ( have to hold your tongue right), the instructions will tell you to install the new one from the top. It's easier to just sit it in the hole and then get underneath to get it thru.
Also about the boot, i agree, it's hard to get on and easy to come off. My console got hot a few days after installation and low and behold it had slipped off!
RE: Hurst shifter
You're right that the stock **** won't work on the basic Hurst shifter that they sell, but there is a Hurst short throw shifter that uses the stock ****. The stock number is just one digit different than the regular shifter. Hurst sells three shifters for our cars. The basic one with the chrome stick and white ball, another short throw that looks just like the factory shifter with the stock looking stick and threads (no chrome Hurst stick) and the billet shifter (that apparently no one has seen yet).
I'm still waiting on my black Hurst shifter ball to come in...had to special order it...hard to find for some reason.
