Yet More Gear Questions
I am considering going to 3:73 gears in my '07 GT with an automatic. I currently have the 3:31 gears. I went to a dealer today to inquire about it and he said that they could put them in but that it would require a retune, that they would have to recailbrate me speedometer and that it could vary well invalidate my warranty if I needed warranty work done on my car. He said that once they change out the gears that it is registered in the PCM on the car and cannot be removed. My questions are as follows;
- Does changing the gears really require a retune?
- Does changing the gears mean that you have to recailbrate the speedometer? I was always under the impression that tire size and not the gearing was the constraining factor on the readout of the speedometer
- Is the changing of the gears automatically recorded in the PCM? Or is it only recorded after a retune?
- What has been everyone's experience with regards to warranty work after you have changed the gearing?
RE: Yet More Gear Questions
ORIGINAL: Captaincobalt
-tire size, and gearing will change the speedo, bigger tires will turn slower than small tires with the same force applied.
-You can untune your car right before you get it to the shop, but some people say the dealership can still see it.
-Warranty work varies from dealer to dealer, some are cool with it, some are not. But ford has to prove that the part caused the problem to not cover it under warranty.
Was the tech telling you it would scrap your whole warranty? If so, he is a lieng D-bag, the warranty is only scrubbed with the replaced part, not the whole thing.
Ktown,
The guy wasn't saying that it would scrap the whole warranty but he was indicating that if they could some how link the problem with the car to the gear change that the warranty would be void for that fix.
So the gearing really does have an impact on the speedometer readout? I am surprised....
I guess retuning it back to stock for warranty work won't help. Bummer.
Thanks for your help....
I checked today at my local Dealership its a SVT one. They said they do the retunefor the speedo. And it does not void the warranty. As long as a Ford Dealer does it. Price sucks though about $937.00 to do it.
Ktown,
Ktown,
Some people say if you disconect the battery for a few mins and drive around, that resets the comp, but I'm not sure if that works.
Spook, if you like getting raped by your dealer I'd say go for it [&:]
1.) you WILL regret not going 4.10s the extra 1 mpg is well worth it
2.) do you already have a tuner? if you do your all set, just reprogram the speedo, if not, talk to justin at vmptuning.com
3.) you need a bering kit as well with the gears
Not a retune but the ECM does have to be flashed to makethe speedo and other things function properly. Beleive it or not the ECM and the way the Auto tranny performs depnds on inputs from the rear end so it does in fact effect more than just the speedo.
Yes as said above
Only after the reprogramming
Every dealership is differant
Yes as said above
ORIGINAL: mustangman02232
Dave Kegel
the bearings are a wise idea regardless of mileage. They're not much more money and it's apart anyway, so why not?
my 4.10's cost me $562 installed with the speedo correction at the dealer. Ford has a flash tool specificly for tire/gear changes.
If you stick with FoMoCo parts and have them dealer installed you should really be okay. If they bark be DIPLOMATIC. if your a jackass they wont work with you. try to always go to the same dealer and deal with the same service writer. they're not gonna screw someone that brings them lots of business.
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
