I found the perfect gear/tire combo for me!
I installed a taller tire (255/55/17)on my car and now my rpms at 70 are around 2350-2400 and my mpg stays over 25 at this speed, With my 4.10 gears and my previous tires which were 255/50/17 my rpms were just a little to high on thehighwayand my car would vibrate and shutter at 75+mph. So after installing these new tires which are a full inch taller, all my pains went away! I can hit 60mph in 2nd gear at only 5900rpms where as before I had to up to 6200 or more...I am really happy about this because I was really starting dislike highway driving and now with this simple tire swap things have changed..I know it seems silly but little things like this drive me nuts!
Happy new years!!!!
Happy new years!!!!
RE: I found the perfect gear/tire combo for me!
Effectively what you have done with a taller tire is changed your gear ratio to a higher gear (lower numerically). I'm sure there is a math wiz somewhere thatcould do the calculation, or even an Excel tool that will do it for you. But with a taller tire, you're now running the equivalent of 3.90s, or 3.73s....maybe not as drastic as that, but you get the idea.
ORIGINAL: AlloyGT07
ORIGINAL: AlloyGT07
I am running 295/45s in the rear with 4.30 gears. That is roughly equivalent to 4.10s with the stock size tires.
Ray's setup with one inch taller tiresis like running 3.95 (if such a ratio existed...call it 3.90 to match what is commonly found)
Yep, the car is silky smooth now, I guess since we can't get the ford racing gears in the 3.90 size then you can justgo with the 4.10's and put a 28 inch tire and boom your problem is solved. I can hit 130mph in 4th gear now where as before 4th would run out hair over 120mph. Another thing to mention is my traction is a little better now as well, I can actually use first gear now!
ORIGINAL: raybroussard
ORIGINAL: AlloyGT07
My stock tires were 235/55/17. My new tires are 305/45/18. I have 4.10 gears. So....
27.18 / 28.81 = 0.943 X 4.10 = 3.868
hawgman, i would love to see pics with that tire on the back, i keep seeing everyone with 295's on the rear but i want bigger than that. i had 295's on my 2003 GT and love the wider sive in the back. are there any clearance issues with the 305's think a 315 would fit out back?
KingRando
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
