question about cams
Im thinking about ordering the cam package from breenspeed for $1k, i was wondering about how long do cam installs take for a shop to do on average? just so i know im not totally getting screwed when i take it in.
RE: question about cams
Unfortunately my cam install took a couple weeks since the speed shop I took it to did not have the the right spring compression tool. Even after they got the tool, they had a bitch of a time getting the springs installed. Still, labor was just over 1000$. But trust me, you'll be happy with the results. I'm getting 321 rwhp with my automatic tranny.
what other supporting mods do you have with the cams? At 321 im sure you have others. What was the actual difference from the cams themselves?
Cams are a 12-15 hour job.
could you do the whole cam package yourself in your garage?
ORIGINAL: Kaldar142 could you do the whole cam package yourself in your garage? You will need a special valve spring compressor (anywhere from $150 - 300 from Ford), an air-hold adapter such as that from a compression tester (keep in mind the odd spark plug threads on this engine), shop air, etc. Your basic stuff like a torque wrench is of course required also. |
Ford will change them for $1500
ORIGINAL: Hufenstang Im thinking about ordering the cam package from breenspeed for $1k, i was wondering about how long do cam installs take for a shop to do on average? just so i know im not totally getting screwed when i take it in. |
Yep, agressive cams are pretty much useless with a supercharger or turbo, and they could even compromise power. If you are going FI, stick with the stock cams.
ORIGINAL: CrazyAl Yep, agressive cams are pretty much useless with a supercharger or turbo, and they could even compromise power. If you are going FI, stick with the stock cams. |
