Fog Lamp Removal
RE: Fog Lamp Removal
Some just posted it a few days ago see if I can find it.
The upper grill is cake to remove. It has 4 tabs that snap into the front fascia.
http://store.roushperformance.com/im...structions.pdf
Remove the radiator cover and then in figure H from the instructions above show the 2 tabs that are on each side.
< Message edited by howarmat -- 1/5/2007 12:12:24 PM >
Thanks howarmat
Thanks howarmat
Really easy.... all you gotta do is pop your hood, take out the little pop in screws on the plastic radiator cover ( I think there is 4?), and then undo the hooks of the front grill (2 on each side, 4?? on the bottom)... that's how I got mine out the other day to put in new fog lights! good luck.
John,
Did you have the fog light deflectors fall off when you did your replacement? Those little black rings? I can't get mine to stay back on since i replaced my bulbs. I also went with yellow bulbs, i no longer get flashed..
you know everyone is talking about those saying they had problem with them, but I never had any problems with anything... Idk though,I replaced my entire fog light, not just the bulb.... So I guess that's just a problem people are having with replacing the bulbs??
https://mustangforums.com/m_2512542/tm.htm
Try this I had the same problem but figured it out and wrote this.
jwog666
12-27-2021 08:09 PM
