Charge motion plates (no tune??)
Ok guys I just got off the phone with diablosport and they are telling me that I do not need a tune whenever I install the charge motion plates. They said just to leave the motor on the car that opens and closes the valves and it will trick the computer into thinking the plates are still there. Before I install these I need to get input from other users here. The guy's name I spoke with was Gary and I asked him twice just to be sure. He said NO TUNE was needed if you leave the motor in place. What do you all think about this?
RE: Charge motion plates (no tune??)
I haven't tried this trick, but it sounds like it might work.
The question I have is would that have the same HP effect as if you had the tune though? In other words, is the CMCP tune just turning off the CMCP system, or is it a combination of that and added fueling or other changes?
As a note, the Ford website listing for the plates and the magazine reviews all state that a tune is required.
[hr]
I was in a bit of shock when GARY at diablosport told me this because based on all the research I have done a tune is needed with the plates. I was calling diablosport to get the tune for my predator to do this but they said NO TUNE. So now I am baffled! I want to install the plates so now what!!! Gary also stated that he spoke to the head ford tuner at diablosport and that guy said they did not see a difference with the tune vs. without the tune... I am stumped now...[/align]
I'm going to elaborate a bit on my earlier post.
The way I see it there are two potential issues here:
First off, there is the communication between the CMCP servo and the computer. And second, there is any potential changes to the tune itself (by that I mean fuel or timing or both).
Of course, if there is supposed to be communication between the CMCP servo and the computer,and you removethe servo(as is typically done with this mod), then the computer will throw a fit. Instant thrown code. So from this point of view, I can see how leaving the motor there would "trick" the computer and there wouldn't be any thrown codes.
But my concern is regarding the tuning. Does a CMCP tune also alter fueling and such? If so, then if you go the tune-less route you will be missing out on some HP because you aren't adapting the fueling to suit.
I've heard your tune must altered for cmdp so the computer doesn't try to activate the sirvo motor that opens and closes the stock plates. Failsafe will occur if you are running a stock tuneor a aftermarket tune that doesn't disable this feature in the tune. This means the sirvo motor can still be plugged in but will not activate at a given rpm because the tune has disabled that feature in the computer.
Tell who ever told you no tune was required, to Lick my *****.. and DO NOT ever order a thing from them or let them near your car.
Yes you can leave the motor connected and the car will still think the CMCV plates are still installed, but it will not be calibrated for the change in flow and that will lead to bad things. And if you have a tuner why the hell would you not just turn of the CMCV plates and remove all the extra crap from the car...?
Needless to say if I was told by DiabloSport that I would inform them they need to close up shop and find another industry to be in. As they have no buisness tuning cars
Yea, it sucks because of course I have the C&L intake and tuner package but I have yet to find a way to get a tune into it so that I can install these higher flowing plates. It can not be that difficult to get a tune right? I wanna stick with the predator because I have already used it to setup all of my other options, gears, tire size change etc......
ORIGINAL: raybroussard
This topic has been covered extensively on other forums. YOU WILL NEED A TUNE. Even with a tune some have reported a loss of power at lower RPM's. They JDM Engineering for tune advice.
w w w. t e a m j d m . c o m
09-08-2015 06:25 PM
