What gas stations??
#66
RE: What gas stations??
ORIGINAL: BlackStang21
[align=left][font="arial"]I don't know where some of you have heard that running anything above an 87 octane with a stock tune will leave deposits in the engines because that is wrong. There are plenty of drivers out there who dont own muscle cars or performance cars and choose to run their cars, which have stock tunes, with 91 or 93 octane and do not end up with deposits. It is simply this the higher the octane the cleaner the gas will burn.
And as for the discussions of ethanol being put into the gasoline. The ethanol they add to the gas only does the same thing that the additives do. It helps the gas to burn cleaner. The amount of enthanol they add to the gas will not hurt your engine.
#69
If you have more than one local distribution point (pipeline, refinery, etc) their may be some differences.
Most places only have one distribution point which means its all the same other than the detergent pkg.
Just buy your fuel from a high-volume station thats a TopTier Certified Brand (they have higher amounts of detergent).
Personally I use Amoco 93 from the local BP. BP kept the Amoco Gas name when they took them over.
They had the best rep of any brand in the US in survey after survey.
Why do I use it? The detergent pkg has a nice smell when you fire it up.
#70
If you guys truely want answers about fuel, oils, octane, ethanol, etc...
you should be reading the forums on www.bobistheoilguy.com
NOT here!
I use BP 93 octane on my GT.
NOT here!
Matt's 95 Stang
10-05-2015 07:16 AM
