CHEAP BLOWER!!!!
#21
RE: CHEAP BLOWER!!!!
they are very much an entry level blower. the belt and bearings eventually will need changing, but they arent that expensive and it's not that hard to do. If your looking for big power they're not the one for you. If you want something fairly inexpensive and want a significant but not huge horsepower increase they are great. My personal feeling is that most of the blowers out there put the numbers way too close to the edge for our short block. like i've already said, it's also very easily removed. i could remove it right now and drop my car off at the dealer by 5. you can't do that with a roots blower.
#23
How many miles were on your pickup?
You see what i'm getting at right? You really can't blame the blower because you weren't impressed by the power gains. Hell for all we know it was producing exactly what it advertised, but your butt dyno wasn't impressed.
After looking at it I think i'll just spend a few thousand more and get the saleen. It does look cheap in those pictures.
ORIGINAL: suoperdave84
No I didn't have it dynoed and I didn't install it myself. A friend of mine who worked for a turbo shop down the street did it at his house. He knew what he was doing. It was a pretty straight forward setup though...not a lot to mess up.
#24
ORIGINAL: Norse1974
Well,,,Do we know anyone here on the site who has this set up?Or will Rodeoflyer be the first?
#25
ORIGINAL: 06GT4RAD
Powerdyne makes a decent Entry Level Supercharger however they will require belt replacements and bearings changes pretty often. I know many guys that had tried them on there F-150's due to the low cost and have spent more on belt and bearing changes putting them at what a Procharger or Vortech would have cost to begin with. Just be advised they are inexpensive for a reason. The Powerdyne also have no room for growth meaning you get what it is and cannot increase boost. Also 7-8 PSI on non inter cooled boost is very dangerous the intake charge is still going to get very hot. Most of the Powerdyne only run
6 PSI because of this
Richard
Richard
#26
ORIGINAL: Ruffnuts
Actually you can upgrade the pully (called powerdyne to ask about it) and since they require no engine oil puping threw then it wont get any warmer then a vorteq or a procharger, and you can easily install an intercooler for one. I have a procharger intercooler from a friend who blew his procharger up and now is gong turbo and i will eventually (once I fabricate the pipeing) intercool mine.
ORIGINAL: 06GT4RAD
Richard
Richard
Richard
#27
The Powerdyne Kit is good for someone looking to increase thier Butt Dyno. It adds about 100 hp, easily installed, and in cheap (complete kit with tune is $2900 shipped). This is good for someone not looking to hard core race, but to keep their engine at a safe level and keep the car at a daily driver status, wouldn't you agree?
#28
ORIGINAL: 06GT4RAD
You cannot upgrade without a intercooler with the Powerdyne. Like i said it is a very Entry Level Supercharger Kit. Everyone i know that has installed one has only had it for like 6 month and then sold it and purchased either a Procharger or KB.And the bearings and belt will need to be replaced even sooner. I know there is a guy on Ebay that sells and upgraded Kevlar Belt and some upgraded bearings but even those only last so long. Also the Procharger does NOT use engine oil it has it's own self contained oiling system. And there base kit is 9 PSI upgradeable to 12 PSI Double what the Powerdyne is.
Richard
ORIGINAL: Ruffnuts
ORIGINAL: 06GT4RAD
Richard
Richard
Richard
#29
There is a difference between adding a smaller pulley and adding a smaller pulley SAFELY. As for your digital Temp gauge test that is no where near accurate enough to even use as data. A digital gauge can not accurately measure air temp flow. I would suspect that your temp readings were more related to underhood heat soak temps than actual air flow intake charge temps. I have already said the Powerdyne is a nice Entry Level kit. My thoughts are if your going to spend 2900.00 for it why not spendabout 1000.00more and get a Procharger. That is what i did for my F-150 When making a purchase of this nature do your research it pays. So far it seems as though you are but consider the long haul not just the short term cost.
Richard
Richard
