long tube headers vs. shorty headers
RE: long tube headers vs. shorty headers
25 is on the high side unless you are FI....the 25 would include x pipe probably
for a n/a car you should pick up 10-15 and a good amount of torq, i know i noticed the torq with mine
Not just the kooks. You can't run any l/t's with a turbo...
For the millionth time, YOU HAVE SHORTIES ON YOUR CAR FROM THE FACTORY. The only real 'upgrade' from stock is L/T's - otherwise your stock manifolds are more than good enough.
ORIGINAL: modaddict
You are right, you will losesome clearance (1" to 1.5") with the SLPs, Iam notlowering so its not an issue, but it is something to take into account. I got a really good deal on my LT headers/X pipe w/cats from a website, install was $450 for all of it, so about $1200 total.
Dyno proven #s , RWHP/RWTQ was +11/+13 not sure about the 25-35 hp people claim, maybe at the crank you gain that much but to the ground I only saw a solid 10-15 hp jump, thats 1 3/4" primaries on a naturally aspirated engine, I plan on getting a blower soon which is when the real benefit of bigger primaries will kick in, at least thats what I hope!!! lol
Here is a pic of the LTs and how they hang.
[IMG]local://upfiles/30381/C4079ED8EAEE427CA80F9043250620C2.jpg[/IMG]
ORIGINAL: techmanBDsStang
Except for that rust look.[:'(]
ORIGINAL: modaddict
ORIGINAL: modaddict
LOL
ORIGINAL: modaddict
Being in CA, as you know with having to be CARB certified, I was looking at the JBA shorties as they are CARB certified, but I also found out that Edelbrock has come out with their shorties and are also CARB certified. It would be nice to see numbers from a customer or indepedent to see if they get the same numbers Edelbrock says. But then again, the numbers they post are probably crank HP's. I would have ot look again, I think they said 15 to 20HP's
I think with Hooker and BBK long tube headers you can retain the factory cats (using their modular mid-pipes)
wouldn't that still make you emissions legal in CA ?
In AZ we are good for 5 years till emissions testing so I got the LTs, but just in case I got the catted version of
x-pipe to match, and my tune disablestheO2 sensors so no"check engine lights".
To me shorties are not worth it unless you shiny stainless steel !! lol
Also while they , or you, are at it go ahead and change out your motor mounts, don't make the same mistake I did.
they are a real upgrade from the crappy stock mounts , easy mod to do while installingLTs ifraising engine.
ORIGINAL: desslok40
Unfortunately no, it has to have a CARB certification. And have the certification number handy when smogged. Ours is 6 years, then every 2 years after that. I don't want to take the time to reinstall the factory for the test.
