Missed Gear = Short Shifter
Ok, I know I shouldn't and I don't know why, but for some odd reason every once in a while when I get on it in first I miss second when I shift. ... now I think it's just because I let off the clutch too fast before I'm in gear. Solution??? Will installing a short shifter eliminate this problem? and if so, I was looking into a Steeda Tri-Ax... That a good choice?? Thanks for the input in advance!!
RE: Missed Gear = Short Shifter
ORIGINAL: AmericanMuscle4.6GT
your pulling the lever too much to the left inadvertently as you shift angrily. try concentrating on going straight back. your grabbing it at a wrong angle i think.
ORIGINAL: howarmat
hurst, problem solved.
second gear on a stock shifter? you shouldn't miss it, it is definetely driver error. you need to do nothing but practice! first start to shift slowly and then get faster, faster and faster... then you will learn how to.. is it only second gear, if it would be 3rd gear, it would be a different story because most of us miss 3rd gear EVEN with short shifter.. practice is way to go brother.
Yeah that's why I said don't ask why lol... I've hardly ever missed third, it's always second, and everyone always says the same thing lol... I'll see about a short shifter, thanks.
09-03-2015 07:14 PM
