HVBoM report from the Ford Parts Dept.
Old 03-03-2007, 12:05 AM
bztz4m
bztz4m's Avatar
Default HVBoM report from the Ford Parts Dept.
I heard about this report that you can get from the Ford Parts Dept. it is called a HVBoM report which is a very detailed report like a build sheet for us Mustang newbies which shows all the features the car was built with. Here is the report for my 2007 GT/CS. The report was 8 pages long and had some good information. So head down to your Ford Dealer to get your report.
Ford Motor Company - HVBOM, Features
HVBoM - Features for VIN : 1ZVHT82H575229344
Model Year: 2007
Company Car: N
Engine Serial Number: 080604404709
Vehicle Calibration Number: 7ZF2G80A
Warranty Start Date: 27-JAN-2007
DSO Number: Selling Dealer Code: 07894
Transmission Serial Number: 07310645027
Exterior Paint Code: HP
Vehicle Line: VLZF
Vehicle Body/Cab: FORD MUSTANG 2-DR COUPE GT
Engine Tag Number: 7S837BA
Production Date: 19-AUG-2006
Warranty End Date:
EUR Paint Code:
Fleet Code:
Interior Trim Code: KC
Tu-Tone Paint Code:
Feature Description Table
Feature Code Feature Description
AIR BAG RESTRAINT - DRIVER
CPGAB AIR BAG RESTRAINT-DRIVER
AIR BAG RESTRAINT - PASS
CPHAB AIR BAG RESTRAINT-PASS
AMBIENT TEMP/SPEED PACK
ABTAA LESS AMBIENT TEMP/SPEED PACK
APPEARANCE PACKAGES
YPJAA LESS APPEARANCE PACK
YPJ01
AUDIO - RADIO FREQUENCY
IBMAB NAAO RADIO FREQUENCY
AUDIO - RADIOS
IBAFC CDX6+ RAD W/ SP SENS VOL CONTR
IBAOO ALL RADIOS
IBA02 ALL NON CASSETTE RADIOS
IBA03 ALL STEREO RADIOS
IBA05 ALL RADIOS WITH CD PLAYER
AUDIO - SOUND SYSTEM
IDAAH SUBWOOFER/AMP. SOUND SYSTEM
AUDIO - TYPE OF AUDIO BROADCAST
IBYAD SATELLITE DIGITAL BROADCAST
AXLE - FINAL DRIVE RATIO - SINGLE SPEED
EGAHD 3.55 FINAL DRIVE RATIO
EGA01 ALL SINGLE SPD FINAL DR RATIOS
AXLE DIFFERENTIAL - REAR
EGJAC LIMITED SLIP REAR AXLE
B&A CONTROL CODES (9270)
TAQAA LESS B&A CONTROL CODES (9270)
TAQG2
TARAE
BATTERIES
HTAAB STANDARD DUTY BATTERY
BODY STYLE
BS BJ 2 DOOR COUPE-4 LITE
BRAKES - ANTI SPIN TRACTION
FEFAB ANTI-SPIN TRACT BRAKES W/O IVD
BRAKES - ANTI-LOCK
FEAAB 4 WHL ANTI-LOCK BRAKES
BRAKES - ANTI-LOCK ABS/TRACTION CONTROL
YCXAB MRKT CB-ABS/TRAC CONT
YCX01
CENTER CAPS-FIA
FIFAA LESS CENTER CAPS-FIA
CLIMATE - AIR CONDITIONING
AC B MANUAL AIR CONDITIONER
AC 1 ALL AIR CONDITIONING
CONVENIENCE GROUP
AAMAM FRONT COMFORT PACKAGE C2
DRIVE
DRB 2 WHL L/H REAR DRIVE
DRT ALL 2 WHEEL LEFT HAND DRIVE
DR1 ALL LEFT HAND DRIVE
DR2 ALL 2 WHEEL DRIVE
DR6 ALL REAR WHEEL DRIVE
ENGINE
EN HZ MOD 4.6L 3V OHC VCT NA ALV8
EN0G ALL GAS/GASEOUS ENGINES
EN 0M ALL MOD 4.6L GAS ENGINES
EN 08 ALL 8 CYLINDER GAS ENGINES
ENGINE - EMISSION REQUIREMENTS
DGAAC CALIFORNIA/GREEN STATE REQ.
ENGINE - HEATER
DEBAA LESS IMMERSION HEATER
ENGINE COVER - UNDER HOOD
C7SAA LESS ENGINE COVER - UNDER HOOD
EXHAUST TIPS
F2EAB ROLLED EXHAUST TIPS
EXHAUST TIPS-FIA
FIEAA LESS EXHAUST TIPS-FIA
EXTERIOR APPEARANCE GROUP
AB2AA LESS APPEARANCE GROUP
EXTERIOR PAINT - ACCENT STRIPE - BODYSID
CJPAX ACCENT STRIPE - SATIN BLACK
CJRAP DECORATIVE ACCENT STRIPE
EXTERIOR PAINT - ACCENT STRIPE - HOOD
CJTAA LESS HOOD ACCENT STRIPE
EXTERIOR PAINT - 2003/04/05/06 EXTERIOR
PN3ER HIGH PERFORMANCE WHITE
EXTERIOR TAPE STRIPES-FIA
FIWAA LESS TAPE STRIPES-FIA
FLEET
YZKAA LESS FLEET
FLOOR MATS-FIA
FIDAA LESS FLOOR MATS-FIA
FOOT PEDAL DESIGN
GCEAB FOOT PEDAL DESIGN - STANDARD
FRONT VEHICLE COVER-FIA
FILAA LESS FRONT VEHICLE COVER-FIA
FUEL - ASSEMBLY PLANT FUEL FILL
FF1AB NORMAL FUEL FILL
FUEL ENGINE FUEL CAPABILITY
GBVAF UNLEADED FUEL CAPABILITY
GBV01 ALL NON FLEX FUEL CAPABILITY
GBV02 ALL GASOLINE FUEL CAPABILITY
FUEL TANK LOCK
GBTAE NON LOCKG FUEL CAP W/BP LABEL
FULL VEHICLE COVER-FIA
FIPAA LESS FULL VEHICLE COVER-FIA
GENERIC COUNTRY GROUPINGS
SATAB GENERIC COUNTRY GROUP 1
GVWS
AAZBB 4450 LB. GVW
AAZ01 0 LB THRU 4580 LB GVW
AAZ06 0 LB THRU 8600 LB GVW
HOOD SCOOP
BLTAA LESS HOOD SCOOP
I/P INSERT
BBQAW I/P INSERT - RIBBED ALUMINUM
INSTRUMENTATION - CLUSTERS
HCFAQ INSTRUM CLUSTER-6 GAUGE
INSTRUMENTATION - MESSAGE CENTER
HKDAB MESSAGE CENTER
INSTRUMENTATION - SPEEDOMETERS
HDHAB MPH/KPH SPEEDOMETER
INTERIOR DECOR LEVEL
bztz4m is offline
Old 03-03-2007, 12:11 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Default RE: HVBoM report from the Ford Parts Dept.
Nice car and thanks for the info...I never heard of it before!
mygt500 is offline
Old 03-03-2007, 12:15 AM
bztz4m
bztz4m's Avatar
Yeah I found out about this report on the Shelby Autos Forum....and believe it or not this is the small report if you checked each option the report would be over 30 pages from what I read.
bztz4m is offline
Old 03-03-2007, 01:10 AM
searay2006
searay2006's Avatar
Wow!
searay2006 is offline
Old 03-03-2007, 01:29 AM
sw07gt
sw07gt's Avatar
What just happened? lol
sw07gt is offline
Old 03-03-2007, 01:35 AM
2006GTSC
2006GTSC's Avatar
I think my head is gonna explode...
2006GTSC is offline
Old 03-03-2007, 01:58 AM
HaneyMotorsport.Com
Banned
HaneyMotorsport.Com's Avatar
This is somewhat new for Ford cars and light trucks. It has beenin existencefor awhile now. It really started for Ford heavy trucks...F650's and up. Ask any Ford parts man who works at a Ford Dealer that works on BIG Fords, Ford class A chassis motorhomes, etc. It can be a Bi!ch to look up the correct parts.
Casey
HaneyMotorsport.Com is offline
Old 03-03-2007, 12:25 PM
shaners90lxhatch
shaners90lxhatch's Avatar
Historical Vehicle Build of Materials. Thiscontains all of your specific vehicle information. I think there are some things in there that the public may not be able to see, but I may be wrong.
shaners90lxhatch is offline
Old 03-03-2007, 12:28 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Yeah we use this all the time at my work. Helps getting the right parts a million times easier. Plus its nice to know what the car came equipped with.
PROMETHEUS PRIME is offline
Old 03-03-2007, 08:08 PM
bztz4m
bztz4m's Avatar
I have a question on the HVBoM report my '07 is a California Special but the report does not have any information about the CS options in it, like the front and rear bumpers since they are different on this car. Is there another report that would tell about the CS option.
Thanks
bztz4m is offline
Quick Reply: HVBoM report from the Ford Parts Dept.
