UDP's Installed
All
I have recently installed a set of BBK UDP's. After the install, the water pump seems to be making a slight clicking/grinding sound(kinda hard to explain), it wasn't there be fore the install, and the install went well. Today, I did a chalk test to see if any thing is rubbing and the test came up negative. Has any one had a similar problem with the water pump? I know a while back a post was on here about the Steeda UDP's. Thanks for all the info in advance. |
RE: UDP's Installed
how do u like them? noticeable increase in power?
RE: UDP's Installed
Sorry you're having that issue. I have some Steeda UDPs I'll be installing soon. I'll let you know if I duplicate your problem.
| All times are GMT -5. The time now is 10:57 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
