throttle lag
throttle lag
hey everyone,how are you.i was wondering if anyone still feels throttle lag sometimes after their intake and tune install.i have an auto and i thought that it was supposed to go away.it doesn't do it all the time.i tried to search this but found nothing.let me know if anyone run into this and how you fixed it.i have a airaid and a diablosport 93 tune.thank you.
RE: throttle lag
If you are using the stock tunes in the tuner...they are pretty much crap....talk to doug @ B amachips.com He will write a couple tunes for you that will blow you away and he can adjust the shift pressure so you do not have the lag anymore.
RE: throttle lag
I've got the Ford racing 93 octane tune (part of the FRPP), and if I leave it "manually" in 1st, 2nd or 3rd and hit the "go-fast" pedal I have ZERO lag and the acceleration snaps my head back now!
The shift points are decidedly firmer now too- while still being smooth.
When I leave it in "drive" and punch it to pass, there's a very slight lag which I've been told is impossible to "totally" eliminate, but it's definitely less of a lag than before the tune.
I've read some postings that describe more "aggressive" aftermarket tunes as causing the automatics to "really slam through the gears", but I don't think that would be very good for the durability of your tranny........
RE: throttle lag
i'm not having to much of a problem taking off from a light.mainly when i push it from a roll sometimes.and i went around a corner yesterday and took off kind of fast and the lag was like 2 seconds.
RE: throttle lag
Depending on how may miles your car has on it, weather conditions in your area, and how many times you have ran the tank really low. It may be the fuel filter. All of the things above will cause your filter to get full of crap sooner.
RE: throttle lag
could the filter being a little dirty cause it to lag a little,i had it for about 3 months but it doesn't look as clean as it did,plus if i have the k&n filter kit,can i use it on any kind of filter.
RE: throttle lag
errrr. In racing sometimes I get lots of lag when the fuel pressure drops very quickly, leaning out the engine, and making it hesitate. However those are not full size racing cars, but, from experience, I say either check fuel filter, pump, all pick-up tubes and if worse comesto worse, it is your tune or just the auto tranny
sry I couldnt be much help[&:]
JDWalton
09-24-2015 08:47 PM
