Saleen experts, let me know
Guys, on buyfordracing.com they are selling 39lb injectors with a 90mm lightning MAF for $319, see link below.....can I use this for my saleen upgrade....will JDM know how to tune for that? and do i need it with the EV1 to EV6 adaptors or without>>>
please advise
here is the link to them
http://www.buyfordracing.com/shop/pr...roducts_id=623
please advise
RE: Saleen experts, let me know
question answered....Thanks hawgman...I will work on that patience thingy....LOL ..also the when calling fordracing, follow these steps
step 1:smash dialing finger in desk draw...this will prevent a mistake from happening...like calling ford racing tech for advice..
Step 2: .then when the need arises to call them again...repeat step 1
thx
thx
39lb cobra injectors are compatible w/ our wiring harness, no adapters needed, they plug right in. The lightning mafs are programmed for 42lb injectors.Your stock maf sensor will workfine, you just need a larger housing (95mm). If you want to switch sensors though Jim prob has a tune for it but check w/ him first .....
ORIGINAL: gloryboy
ORIGINAL: cheftjpeck
so I am going to buy the package from buyfordracing.com. it is compatible with my setup...if i get the 90MM MAF do I use my stock sensor or the sensor included with the unit.I mean if you look at JDM's site it is the same 90mm MAF with there upgrade kits...it states a 90 MM MAF then the harness which I will get from Blueoval for cheaper as well..
ORIGINAL: gloryboy
Just make sure who ever does the tune knows what MAF you have. The FRPP "lightning" 90mm is calibrated different than the SCT 90mm, which they have 2 versions for hp. There are different transfer functions for these MAFs.
The engine’s air/fuel ratio and spark advance are primarily determined by the computer from the input received by the MAF meter.
I would personally use the JDM setup. Jim has done a ton af testing and has the Saleen blower setup down.You may spend a few more bucks, but in this game, it is Always better to do it right the First time around!
Casey
ORIGINAL: HaneyMotorsport.Com
Just make sure who ever does the tune knows what MAF you have. The FRPP "lightning" 90mm is calibrated different than the SCT 90mm, which they have 2 versions for hp. There are different transfer functions for these MAFs. [align=left]The engine’s air/fuel ratio and spark advance are primarily determined by the computer from the input received by the MAF meter.[/align][align=left]I would personally use the JDM setup. Jim has done a ton af testing and has the Saleen blower setup down.You may spend a few more bucks, but in this game, it is Always better to do it right the First time around![/align][align=left][/align][align=left]Casey[/align][align=left][/align]
Saleen / JDM Stage 1 425RWHP Supercharger Package
425RWHP! Everything you need to make your 2005-2007 Mustang move! Saleen / JDM Supercharger Stage 1 Package Includes:
• Saleen Supercharger Kit
• XCalibrator 2 Tuner
• Cold Air Kit JDM Cold Air Kit
• 90mm Mass air 90MM Lightning Mass Air
• Harness 90MM Mass Air Harness
• 39 LB. injectors 39# Ingectors
• 3.60 Pulley
• Belt Gates Belt
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
