Want to start modding - NOW WHAT??
#21
RE: Want to start modding - NOW WHAT??
ORIGINAL: sw07gt
How much did your custom turbo run you?
Powerhouse turbo kit with a custom 76mm Precision head unit and precision exhaust housing - $5,000 (The PH kit comes with a 67mm Precision head unit)
Tial 50mm BOV to atmoshere - $499
Changing the PH kit to be a blow through vs. a draw through - $500
Reconfigure and change the dowpipe, kit piping, and CAI to function better - $500
Change the exhaust housing to a Turbonetics with a Q trim and fit to 76mm Precision head unit- $900
Custom plumb a water aftercooler to aid the kit air intercooler - $500
I guess about $7,900
I still really like the PH kit and for the street it is a great kit as is. For what I wanted to do, the 67mm wasn't near enough potential. It runs out of gas in the 14-15 psi range. There 'custom' 76mm was a way too big on the exhaust side and was suitable for a big block. Took me literally 5-6 secondsw to spool that beast and drove my intake and tranny temps through the roof. I swapped out the exhaust side for a Turbonetics muich smaller Q trim and got the best of both worlds. The kit has the power of the 76mm but spools full boost by 2800 rpm within 2 seconds on the brake.
#22
ORIGINAL: fordfanboy
Steeda makes inferior suspension components plain and simple and anyone who has done any serious modding will agree with me. BMR, CHE, and some others are a much wiser investment IMO.
The steeda CA's are a joke no doubt about it. Myself and several others have broken the crappy eurethane bushings in them several times. I broke 3 sets on the stock motor.
There are a few Steeda parts which are quite good, but the majority of them are overpriced and the quality is towards the bottom of the barrel!
The only Steeda parts I would use:
Springs
Rear swaybar (though it is overpriced)
G-trac brace (this is one part they make better than BMR. Very odd!)
#24
The parts are all the same, you just don't need the adjustable versions and you don't need to fiddle with camber or alignment.
LCAs
Shocks/struts
rear sway bar
Panhard bar & brace
...and so on...
LCAs
Shocks/struts
rear sway bar
Panhard bar & brace
...and so on...
Calizic
08-28-2015 01:46 PM
panic
08-25-2015 09:34 AM
