Shifter Clanking HELP
I have a B&M shifter and I have started to notice a clanking sound when driving. It acts and feels almost as if the shifter is bouncing off the transmission, but everything feels tight. If I push down on the shifter the noise will stop, but if I pull up on it the noise becomes worse. Also when I floor it you can see the shifter move a decent amount. Do I just need bracing or is something loose? Thanks Sorry my car is manual too.
RE: Shifter Clanking HELP
My hurst is starting to do this on my bumpy dirt road, it's annoying. Sometimes it sounds like a grinding and sometimes it sounds like the bushings squeeking. I tried some poly bushinglube on the body bushing, but it didn't really help. All my mounting points are tight.
Originally I wanted the Hurst Shifter, but since B&M bought Hurst they are changing the design or something and aren't sending any out. So I got the Steeda Tri-ax instead. Haven't recieved it yet but I hope it's good!
From what I hear, all short shifters are doing this. I think its because of being on poly bushings instead of rubber which absorbed the vibration. I am going to look into my Roush shifter today. I think I may have tracked down where that vibration is coming from and ill keep everyone informed
ORIGINAL: Tommy07
Thanks for the feed back I am going to takea look inmine today and see if I can find anything. What worried me is it did not do it just after it was installed.
junior04
09-28-2015 10:53 AM
