12V source to power a gauge
I'm just about ready to install a Auto Meter oil pressure gauge on my GT. The only thing left to figure out is how the heck to power the light?
I did some searches and found this thread that shows some wiring:
http://forums.bradbarnett.net/showthread.php?t=19004
He used the transmission light, which will work, but I understand it will leave the aftermarket gauge a little dimmer than the rest on the dash.
Two questions:
Is there a better 12 V to power the LED in the gauge?
Stupid question: Will wiring the gauge into the starter wire trip the factory alarm? (not for the light, but to power the gauge)
Two questions:
RE: 12V source to power a gauge
My gauges wired to my lights. As soon as I turn on my lights, even the runners, the gauges come on too. They aren't any dimmer for me at all. And actually, mine are wired to our little switch that allows us to dim the lights in the car. So as I dim/brighten my dash, so do my gauges.
I looked under the dash and found two wiring harnesses running from the module that works the lights. There a lot of wires there.
Which one did you use? I'm trying to cut as few wires as possible.
ORIGINAL: cryptic26djp
let us know how it works out. i will be installing mine next weekend (knock on wood).
The hardest part has been finding out which wire to use and what piping I should buy. From the looks of it, though, the installation won't be too bad.
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
