Best Aluminum driveshaft ?
#21
RE: Best Aluminum driveshaft ?
I have the Denny's 3" steel DS waiting to go on.
http://www.dennysdriveshaft.com/html/ford_mustang.html
#22
+1 on the Denny's driveshaft. It is 23lbs. but it is a 3" shaft as compared to the 17 lbs. 4" aluminum. I am no expert on the subject of rotational mass, but "I think I heard" that the heavier 3" shaft has less rotational mass than the lighter 4" shaft.
Someone with more knowledge may speak up.
Later
Later
#26
3", 3.5", 4", steel, aluminum, they're all going to give you about the same performance. Just need to make sure you purchase from a reputable builder and it has the type of warranty you can live with.
#27
If your a decent driver you will knock 2 tenths from your 1/4!
ORIGINAL: Daniel60
Well I'm excited and I think I will get this next. How much more horsepower someone? At least if I get this it will not wake up the neighbours as long tube headers will and I could save some money too. anyone?
#28
ORIGINAL: scramblr
#29
ORIGINAL: offrdmania
A warranty isnt going to help you when you install a 4 inch aluminum shaft on a lowered stang and rub the sh*t out of your floorpan over bumps possibly unbalancing the shaft or worse, having it come apart...
ORIGINAL: scramblr
