SCT Livewire
RE: SCT Livewire
Well, unless you plan on using it as a guage (which requires additional sensors $$) then I'd say go with the SCT Xcal2...
I just went thru that decision myself, and the livewire looks cool, but really offers no advantage over the XCal2 tuning wise...
RE: SCT Livewire
i just got mine the other day actually yes well it is an sct btw.
Tunes are the same but it does function goot as a gauge however is rather large and bulky and the cable without rinning behind dash gets in the way. so it is not good for daily driving. hangs low by your foot hard to conceal. your better off just buying gauges. one advantage is that you get a data logger and you can measure your performance. it also has a shift light although ti is quite small. so basically if you want it for everyday.... buy a dashhawk and an xcal2 yes it is 2 diff parts btu the dashhawk is smalled and easier to mount. also the livewire cable is plugged in at bottom(gets in the way) so unless it for jsut at track get an xcal2 and custom tunes and look into a dashhawk or gtech pro meter
09-01-2015 08:16 PM
