procharger gets installed next week
Old 04-20-2007, 09:03 PM
Kronik
Kronik's Avatar
Default procharger gets installed next week
Well finally i get to have my procharger installed this coming tuesday. i just wanted to ask those with sc and tunes did you start running the higher octane right before you had a tune installed. im asking this because ive been running 89 ocatane till now i just ran my tank down till it was on E then i went and put in 91 ocatane will this casue any issues.
Kronik is offline
Old 04-20-2007, 09:06 PM
Dex
Dex's Avatar
Default RE: procharger goes in on tuesday
nope, you can tune your car to an octane so tell them to tune it to 91. or if you wanna run it at 88 then tell them 88. Im getting my car back tomorrow with a turbo in it. good luck waiting!! haha its sooo hard
Dex is offline
Old 04-20-2007, 09:42 PM
Kronik
Kronik's Avatar
Ok then those of you with superchargers what octane are you all running at
Kronik is offline
Old 04-20-2007, 09:50 PM
cheftjpeck
cheftjpeck's Avatar
running at 93 octane.....
cheftjpeck is offline
Old 04-21-2007, 11:49 AM
forensicsteve
forensicsteve's Avatar
My Procharger manual states the following on page 27
WARNING
The car must be operated on 91 or higher octane fuel. Do not run your supercharged Mustang on any gas lower than 91 octane!
I put in 93 octane on the way to the speed shop right before install.
forensicsteve is offline
Old 04-21-2007, 12:21 PM
carmanwelder
carmanwelder's Avatar
Default RE: procharger gets installed next week
My KB SCer will be installed next week. I asked my installer if I should start running high octane now, he said it may be a good idea so when the insatllation is done the correct octane would be already in the car.
carmanwelder is offline
Old 04-22-2007, 04:07 PM
Kronik
Kronik's Avatar
Is it alright to have a 91 octane tune and run 93 octane if there is no 91 around will that harm my car
Kronik is offline
Old 04-22-2007, 04:27 PM
Timmay!!!
Timmay!!!'s Avatar
Nah that shouldn't hurt. A lot of times when people are tuning a car on the dyno they will run a higher octane than they are tuning for to fight off detonation.Have you found 93 around the local area?
Timmay!!! is offline
Old 04-22-2007, 05:03 PM
Kronik
Kronik's Avatar
no only the one on base which is 91 but most of texas runs 93 that is my concern since im going to travel to texas in the summer and my tune is going to be a 91 so if i understand the manuel correctly i should be ok with a 91 tune and putting in 93 octane when im in texas with out changing the tune or having a retune
Kronik is offline
Old 04-22-2007, 08:59 PM
cfr865
cfr865's Avatar
You will probably lose some power running the 91 vs. 93 oct. tune, I know when Brent at Brenspeed tuned mine he asked serveral times if I had a full tank of 93 oct. he didn't want to advance the timing to far , and cause harm to the engine.
cfr865 is offline
Granatelli Sales
01-20-2020 12:34 AM
ChampInSD
10-02-2015 04:55 AM
Dragonus18
09-09-2015 01:21 AM
Luke9222
09-04-2015 06:46 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: procharger gets installed next week
