Ceramic
Old 04-22-2007, 02:49 AM
bobsmilie2000
I ♥ Acer
bobsmilie2000's Avatar
Default Ceramic
Are ceramic headers worth the extra money? What do they help with besides keeping the pipes cooler?
bobsmilie2000 is offline
Old 04-22-2007, 04:11 AM
Simon1
Simon1's Avatar
Default RE: Ceramic
If I were to do it over again i would get the ceramic coated. The reason is the heat that the uncoated radiates through out your engine compartment were as the coated type are supposed to run cooler. It doesn't help with HP or TQ that I know of, but less heat in the enige compartment means less "weathering" of your rubber hoses, electrical circuits and so on. Heat is your enemy in the engine compartment. I have never seen or read anything on how much it reduces engine compartment temps, but the difference between my stock manifolds and the headers (heat wise) is dramatic.
Simon1 is offline
Old 04-22-2007, 04:22 PM
06GT4RAD
06GT4RAD's Avatar
Default RE: Ceramic
Not to mention that the coated headers will saty looking good, while non coated headers start to rust and discolor.
Richard
06GT4RAD is offline
Old 04-22-2007, 06:29 PM
GT Bob
GT Bob's Avatar
Default RE: Ceramic
The more heat you keep in the pipe, the less gases in the pipes cool. Cool gases move slower than hot gases. Slow gas = more backpressure. Theoretically, you may see a HP or 2 difference between them on an NA. Mostly, those coatings were developed for Turbo guys, who need every bit of heat they got to spool. However, in reality, the biggest benefit is what Simon1 and 06GT4RAD said, plus it helps keep your intake temps lower by lowering underhood heat.
GT Bob is offline
dickson
01-23-2005 06:19 PM
Quick Reply: Ceramic
