I'm Blowing Myself Today..TUNED!!!
RE: I'm Blowing Myself Today
The lighting maf to stock maf wiring adapter just pushes onto the stock wire. It doesn't lock into place. I can just pull them back apart with little effort. Anyone know if anything is wrong? or is this how it's supposed to be. I'll have to call JDM in the morning if I can't figure it out.
I read someone else having the same problem. Use some zip ties for a temporary fix.
ORIGINAL: drbobvs
That's correct, there is no locking mechanism on the adapter. I used electrical tape to keep them together.
You did good getting this far! I took me longer but when I got here it was all cake. I didn't have any issues. Engine started right up and that was it.
When you call JDM talk to Jim jr. directly if he's around.
Good luck!
Good luck!
I installed a whipple on my stang, i'm going through a similar problem, but my none supercharger converter is throwing everything off, good luck bro.i'm taking mine to the shop to install the stock converter.
