CMRC Delete Kit tool question
I know there have been a lot of posts about CMRC Deletes but I could find anything about the release tool that is used in this article for disconnecting the fuel line. Are they easy to locate or can something else be used inisplace. Alsois there anything else that might try to throw me a fit during install, because I hate when I hit snags. I mean the install seems pretty straight forward, but it may just seem that way until I try to dig into it.
RE: CMRC Delete Kit tool question
You don't need that tool to install the CMCV delete plates.
Again I repeat you do not need that tool to install the CMCV delete plates.
I personally have installed them and would know, as well as anyone else who has done the install. All you are going to need to do the install is a few sockets and extensions.
-Jeff
-Jeff
Agreed. Just pull the injectors out and flip the complete harness over the plenum to the drivers side. Lay it upside down on the drivers side out of the way. Now you can pull the plenum off. 1 hour job....
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
