Power + Rpm + shift point?
Old 04-29-2007, 09:39 PM
AmericanMuscle4.6GT
AmericanMuscle4.6GT's Avatar
Default RE: Power + Rpm + shift point?
its all about your torque curve. study it, and see where power drops off significantly, shift before that, but high enough that you'll still be in your powerband when the next gear hits. its different in every gear, obviously an example is 3rd to 4th
AmericanMuscle4.6GT is offline
Old 04-29-2007, 10:03 PM
GT Bob
GT Bob's Avatar
ORIGINAL: 07GTEddy
Thats good to know, Thanks!
I guess even though the engine is sounding cool revin up there, your actualy slowin your self down............
Thanks 05.............
Not exactly true. You have to take in to account the torque multiplication going on in the transmission as well. To make it easier to understand, let me give you an example and understand that these numbers are just for ease of illustration.
SUPER SIMPLIFIED EXAMPLE :
Your car has makes 100 horsepower, reguardless of RPM. If your in first gear, andit hasa ratio of 3.00:1, that means your car will accelerate as tho it has 300 Hp and a 1:1 gear ratio. You run your car out to redline and shift into second. You stil have 100 horsepower, but now you have a 2.50:1 gear ratio. Your car will now accelerate as tho it has 250 horsepower and a 1:1 ratio, Shift into 3rd (say 2.00:1 ratio), and now you will accelate like you have 200 hp and a 1:1 ratio.
Now, that is a SUPER simplified explanation, but it gets ya started in the right direction. Now, you have to add in the inertia of the car, the powerband the car has, Gear ratios in the trans and rear, and about 3 million other variables and you begin to see where this gets complex. Auto crossers may hold a gear and push the RPM's simply for the benefit of maintaining power thru a turn, whereas drag racers wanna burn thru the gear and get to the next one. It depends on application.
A good rule of thumb for Drag racing is, you want to come out of gear just after peak power, and come back into it right before peak torque. Ideally, mechanically, this will always happen. However realistically, it rarely does so my rule of thumb is, shifting into 2nd, you time the shift to come in just before peak torque, and run it out to just past peak power, and come into third wherever that puts ya.
GT Bob is offline
ChampInSD
10-02-2015 04:55 AM
Pyrate Dave
09-10-2015 07:30 PM
zanemoseley
09-06-2015 12:58 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Power + Rpm + shift point?
