Describe 'pinging'
Describe 'pinging'
Could someone define the 'pinging' sound for me? It is metallic from what I've heard, but is it loud? Could it be mistaken for another rattle inside the car?
I'm hearing a rattle coming from the dash area starting at around 3k at WOT and I'm wondering if it could be pinging. If I open my windows I don't hear the noise anymore, it probably gets covered by the road and exhaust noise.
RE: Describe 'pinging'
What your hearing sounds like a rattle in the dash. Pinging from your engine happens at very high rpms in most cases, unless your tune is really bad lol. Sounds like 2 bbs in a tin can and add engine the roar of your engine. IMO you can hear it better with the windows down. At 3k RPMs I imagine yours is just a rattle. Since yours goes away with windows down, it's something in the dash. However I could be wrong, and you should try and fix it if you can. If your car is in fact pinging at 3k it needs to be fixed. Good luck fixing it, with the gas in Arizona here, I have gone through 3 different tunes, and depending on the gas I can still get it to ping at 5800. Sometimes it don't, sometimes it does, wish gas was held to a higher and more consistant standard.
ORIGINAL: sycd
http://www.youtube.com/watch?v=ZV1o6sOSQNM
ORIGINAL: wmtheflash
I think it sounds something like this, right? Someone else would have to confirm.
ORIGINAL: sycd
To those that are shugging it off based on RPM: I thought pinging was more prominent as the load on the engine increased, not just the increase in RPM. Sometimes I think I can hear a hint of pinging (nowhere hear what this vid sounds like) if I happen to punch it at, say, 2k-2.5k rpms in 3rd or 4th gear. Do you say then that it's impossible for the noise I am hearing to be pinging? (you very well may be correct, but I always thought it was pinging, and the computer retarded the timing to get rid of it).
Guys, thanks a lot for the input. My car doesn't sound anything like that video, thank god. From what you're saying it really sounds like a dash rattle. So the good news is that my engine is probably not on the brink of destruction caused by detonation The not so good news is that I have now to figure out where that rattle is coming from [:@]
Yeah, it sounds like a dash rattle, although the manual does say a little knock is normal. I've experienced all sorts of breakdowns, but never had a car that knocked before. Here's another Mustang with what sounds like knock to me...
cardsrus1
19
09-15-2015 08:37 AM
