MEZIERE ELECTRIC WATER PUMP
RE: MEZIERE ELECTRIC WATER PUMP
since you have the UDP it will only give you around 2-3 extra HP at the most since the Pulleys are already squeezing the hp out. I wouldn't do it personally unless you were supercharged and even then I would have a cirquit to warm me when it fails because it could cost you your engine. I prefer a belt driven waterpump because if the belt breaks you loose a/c powersteering among others that let you know the belt broke with the electric it will be a slight poof in the engine bay-.-
Andrew
Andrew
Absolute must have mod for any serpentine driven FI...period. Bend a tensioner or lose a belt just once and you will instantly know what I am talking about.
Not needed for N/A but a must have for s/c.
ORIGINAL: androdz
Andrew
Andrew
You lose a belt - you know it INSTANTLY. What you DON'T want is to have your car towed because you can't drive it. With the EH20 pump, you'll be able to ddrive the car around 30 miles before your battery runs out.
ORIGINAL: fordfanboy
LOL - there is no way you have ever tossed a belt with a s/c to make that statement. You will know if you tossed a belt instantly regardless of what H20 pump you have and I'm sorry, but it's a little more than a 'poof' in the engine bay.
ORIGINAL: androdz
Andrew
Andrew
Cheers Andrew
I didn't get a PM from you??
I understand the no warning if the pump fails and having a monitor for E pump is a good idea. I was commenting specifically how you said 'IF THE BELT BREAKS' - you're post wasn't talking about just the pump failing, but specifically that if you tossed a belt, you wouldn't know it with the EH20 pump and that's why I said, 'LOL' cause if you toss a belt, you'll know it real quick regardless of what type of water pump you have.
ORIGINAL: lynwood78
Anyone running this H2O pump on their stang? Is it worth it? Thanks
Hi lynwood78,
I have one on my 2005 GT w/5speedand on the dyno it was good for somewhere between 8-12RWHP depending on RPM. It is also thea goodthingto install ifyou live in a hot climate and have a tuner that allows you to tweak the radiator fan on-off trigger temps. as it can keep your engine much cooler than a mechanical pump in traffic on even a warm day.If youinstall a Meziereyou can get your engine temps down between passes at the drag strip which makesfor lower and more consistent ETs.
HTH!
