quarter mile question
Old 05-12-2007, 11:59 PM
moosestang
moosestang's Avatar
Default RE: quarter mile question
What have you done to the car? Is it completely stock? Put 22 inch rims on it or something? 500lbs worth of stereo equipment maybe? An anchor chained to the rear bumper possibly?
ORIGINAL: jlgtmustang06
i have no clue what was goin on runnin on 87 octane it feels like the punch is good but something is restricting it when i get into the higher rpms any info you need i can tell you to try to fix this maybe it was just that night i think w/o the gf it woulda been 14.5ish
moosestang is offline
Old 05-13-2007, 12:13 AM
06musgt
06musgt's Avatar
it seems that my car is alot stronger in the high rpms,something doesn't seem right.
06musgt is offline
Old 05-13-2007, 12:20 AM
jlgtmustang06
jlgtmustang06's Avatar
completely stock nothing done no stereo no weight i mpissed now i dont know wtf is wrong with it helppppppppppppp
jlgtmustang06 is offline
Old 05-13-2007, 01:29 AM
TheDarkPath
TheDarkPath's Avatar
The very first time I went to the track in my 06 Auto GT, I ran a best of 13.908. My best 60' was 2.09. This was in 95 degree heat and about 83% humidity (Houston, TX). The next time I went, the track was slick and it was about 97 degrees and 80-something% humidity. That was not a good day for me...I ran a best of 14.1 and a worst of 15.2 (2.5 60' and no traction all the way down the track). I ran a few 14.5s with 2.3ish 60'. There was no getting out of the hole that day and around mid-track, it got kinda slick and you could feel power loss due to traction loss. Maybe the track you were at wasn't prepped well...if that's the case, then some of your problems could be attributable to it.
There's always next time and there's huge amounts of room for improvement so just try to think what you did and what happened when you ran the worst times so you can look out for that next time. It doesn't sound like you did anything that worked for you but when you find it...you'll know and you'll really get hooked!
Edit: The above was when my car was bone stock (I still had the dealer plates that first time).
TheDarkPath is offline
Old 05-13-2007, 04:14 AM
Bluestar
Bluestar's Avatar
Maybe he has the emergency brake stuck..........JK, Try making the run without your gf in the car, even bone stock with no mods you should do high 13's.
Bluestar is offline
Old 05-13-2007, 05:25 PM
jlgtmustang06
im not sure what it is these times you guys are gettin what octane are you using do you have the tcs on or off maybe i was spining tires through first gear i dont know it didnt feel like it i just know that my car is more thancapable of doin better than a 14.7
Old 05-13-2007, 05:45 PM
fordfanboy
I ♥ Acer
fordfanboy's Avatar
Your times are not 'shocking'. Bad = yes - but I have seen guys run those times at the track several times. The Driver can be responsible for 2 seconds of time easily. No need for TC to be on ever down the 1320' under any circumstances.
I wouldn't go out and kick the car just yet. Search around and learn up on some drag racing tips/tricks.
Then - go out and buy a CAI & tune and a Torque Converter and you will see amazing results.
fordfanboy is offline
Old 05-13-2007, 06:04 PM
tonkpils555666sas
tonkpils555666sas's Avatar
sorry if i totally missed it, but is your car stock?
tonkpils555666sas is offline
Old 05-13-2007, 06:42 PM
jlgtmustang06
completely stock
Old 05-13-2007, 06:49 PM
tonkpils555666sas
wierd... I have an automatic and I launch the car at 2 grand with traction control off. with my mods I am only able to pull a 14.1 for my fastest time at like 102 mph... but I also spin a little tire off the line... I would expect a stock to be doing at least 14.5... I have read about stock GT's running in high 13's which I dont get how that happens...
Quick Reply: quarter mile question
