What do you guys think?
RE: What do you guys think?
IMO it's a good package if you leave the rest of your suspension stock. Neither the UCA or LCA are adjustable so if you install lowering springs or driveshaft, etc.,you may have to buy an adjustable UCA or LCA to re-set pinion angle. Otherwise, I'd say go for it.
Has been discussed before... If I can remember correctly, it kinda helped a bit, but not in that way that most would think about it... search for CrazyAl, he's done lots of explanations about suspension work... hope it helps, and don't take my advice as a no go
Steeda tends to market some things in such a B.S(!!) way sometimes. They expect people to believe it's the best simply because their name is on it.
That kit will eliminate wheelhop but is only worth a crap oncar with stock springs. Neither the upper or lowers are adjustable, so how would you correct pinion angle? Faster times on the road course - with all poly bushings it will bind up. Steeda does make some nice items but this is mismatched and mismarketed.
