SCT tuner installed
SCT tuner installed
I'm pretty sure I did it right but want to check I'm clueless at times. I was on the 91 tune and just changed it to 87 want to see how it runs on that tune. Here is what I did
1. select tune 87
2. turn key on
3. optional parameters = no
4. keep previously entered options = yes
5. program = select
Then it went into checking stock calibration & earasing module
Program loaded select and turn key off[/align]
1. select tune 87
2. turn key on
5. program = select
RE: SCT tuner installed
bobsmileie I totally worded this wrong I want to make sure I did it correctly 1st time changing it. Anyways it was correct and didn't see much difference between the tunes. The performance I have with the tunes are way better than stock it may be me but I see I can shift at a higher rpm with no engine strain. Feels faster and gas milage is better if I stay off the gas. A little low engine idle on start up in the morning. I'm happy with it I now want more power.
join the club! lol
yeah sounds like you loaded the tune just fine....
ORIGINAL: GT06stang
Didn't take long to catch the Mod bug, I do have 1 concern with the set up. When I turn the car off it I noticeda short burst of air like a release valve going off. It's a air burst that's about 1/2 second long any idea what this is or is it normal with the JLT.
this is normal and it's been discussed, don't remember
exactly which thread tho....
ORIGINAL: GT06stang
Thats your open intake farting when you turn the car off. heeeheeee. If you ping, go one tune down with one octane higher. pinging will stop. Ex. 87 tune - 89 gas. Brenspeed told me the diff. in hp between 87 and 93 tune is marginal. congrats !
Not worried about gas mileage just noticed not much of a change, as for the drone @ 2500 nope no drone smooth sound I don't recall saying anything about that. ezio350 & hammeronthanks for your comments. Over all I made the right choice on the JLT and SCT Tune AND yes I will be going back to the 91 tune just wanted to see the difference if any between the 2 tunes. Thanks everyone for you comments.
Luke9222
10-22-2015 11:55 PM
09-01-2015 08:16 PM
