I cant stop spending money!!
RE: I cant stop spending money!!
Obsession,I think not. It's good for the economy! Plus it makes you and your mustanghappy. It worse than drugs and just as fun. Did I just say that......Buy Buy Buy......hell you only live once! You are judged by the car you drive!
ORIGINAL: bobsmilie2000
will it ever end?
will it ever end?
If you already have one and she has no major issues with your 'affliction' then you are truly a blessed man.
That should be the phrase of the year! I'm sure everyone can relate here, I'm also planning on getting 4.10's installed tomorrow hopefully. If I can make a suggestion. I would pass on the cams & TB. Unless your planning on building up that engine and doing some headwork or adding asuperchargerthe cams just won't be worth it for the money you'll lay out. You may gain some hp but your going to lose some torque. Also there's not one TB except for the GT500 package that JDM has put together that's going to do anything for your setup except cause problems while maybe adding 2-5hp at best. The GT500 one won't gain you much hpagain unless you have a built up motor and a supercharger. Even then you need to be running some pretty hightboost to see the best gains. Just some suggestions but there's plenty of cases to support this information. Good luck.
400 N/A is not an easy task...
are you talking 400 crank? or 400 wheel?
cause for 400 wheel you'll need to do heads, cams and other internals...
note, a cam alone is useless...and stay away from the throttle body...
do the pullies, delete plates, finish your exhaust, an intake and a good tune and you'll be sittin round 340 wheel which is about 390 crank...
the next thing is internals...but you gotta do cams and heads to really notice a difference, cams alone are useless and from what ive heard a good set of heads are the answer over cams...i'd leave the cams stock...
ORIGINAL: Rudiepoo1
https://mustangforums.com/m_2284371/tm.htm
