Need help TCS
Need help TCS
Hello everyone , im new in the stang world , and yesterday i noticed that TCS BRAKE AIRBAGindicator were lit , and im desperated , and ill bevery happy if someone came up withany help that can fix that curse jejejeje ,plus the tcs button doesnt work help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
RE: Need help TCS
well, first off, welcome to the forum. second, you seem to have one heck of a problem...i'd say first, disconnect the battery and see if everything goes away after the reset. if not, take it to the dealer. that might be a fuse or relay somewhere or your ECU spazzed out.
RE: Need help TCS
TCS uses your abs system, so it doesnt surprise me that it doesnt work either. You really need to see someone who is certified to work on your cars abs system like a ford dealer would here in the US. If your abs is faulty that poses a saftey risk for you. Could be nothing but it could be something. Troubslshooting anti-lock brakes over the net though might be a bit dangerous even if someonewho knows the system replies. Not that you'll get bad advice just one of those things I wouldnt t/s over the phone so to speak.
RE: Need help TCS
...wait. you wash the motor? like the actual motor? if so, you probably wet some wire somewhere and in that case, you definatly blew a fuse or a relay. I'd go over to the fuse panel and pull out the ABS, TCS, and some similar fuses and check if their blown. Then find the relays for those same accessories and replace them.
