Brake Rotors
RE: Brake Rotors
Dont the bigger brakes require 18x9's or 10's? That is what I have come to understand checking out the possiblities, which would mean new wheels and tires so if correct a brake upgrade could end up costing close to 5k?
RE: Brake Rotors
Although I did the drilled/slotted rotors, it's only for looks. Since you already have the pads, pick up some of Earl's Stainless Steel brake lines. The pads and lines will give you great improvement over stock. You can get the lines here: http://www.ls1speed.com/catalog.cfm and search for this part number: EARL28B600
RE: Brake Rotors
Then get some replacements from here.
http://newtakeoff.com/index.asp?Page...mp;Category=91
cheap as can be
cheap as can be
RE: Brake Rotors
The Rotor-pro rotors are very nice. The ones you have shown are the base version they also have a upgraded version that comes with the hat area powder coated black, however the Zinc coating is not offered on that version. The price really is unbeatable. I would also suggest upgrading to the Stainless Steel braided lines as that will help also. I am going with the Steeda Lines basically because they are designed exactly like the factory lines with mounting brackets. I have been debating which pads to go with and honestly did not want to go with HAWK HPS pads but everyone says they are the nicest setup short of going with race pads which i do not want. I have HAWK pads on my F-150 and they squeal to all hell which is why i do not want to use them. But figure i will give them another chance. These three mods combined will offer slightly improved braking over stock.
Call Richard @ Rotorpros he has a special going now for TMS Members
Richard
Richard
RE: Brake Rotors
I got mine at Performance Plus Brakes aka Brake Planet. Cheap and cool!
Here is a look
http://picasaweb.google.com/1BADD05/...15895421877842
Here is a look
