? about FRPP differential girdle???
RE: ? about FRPP differential girdle???
he got gears so why not replace it while you have it off...i dont think there is much performance gain. I will be getting one with my gears. its only another 187 ontop of the 210 for gears and then maybe 400 for install.....money grows on trees right....
ORIGINAL: likemike99
What does that do? I mean besides lighter than the stock one, what is the advantage to upgrading it? What if you are keeping the stock gears, is there still a reason to get it?
It's not lighter than stock by any means. The stock cover is thin and weighs nothing compared to the ford racing one. The cover itself is supposed to strengthen the rear end housing and the stop bolts are supposed to reduce deflection of the differential bearings. It's supposed to give your gears a longer life, but IDK about that.
You can get the lpw girdle for $50 cheaper than the ford racing one.
ORIGINAL: probinator
*** another thing to buy. damn.....
I want to do my gears next week. hahah. I was out of debt till this mod bug.
Not the G2 girdle, it's made specifically for the 2005+ mustang. My aftermarket panhard bar is very close to it though.
ORIGINAL: Mikes_BLK_GT
Dont you have to relocate the panhard bar for the new girdle?
I had to relocate my panhard bar for the aftermarket girdle, so the mounting bracket ended up movingthe bar backby about .5"s. The relocation bracket is about $40. It depends on what aftermarket Girdle you have though, mine was 3/4"s thick, where as the stock one was probably 1/4" piece of aluminum.
[IMG]local://upfiles/67698/93B76CF584CF451B84B024EE1E7CE96C.jpg[/IMG]
What girdle do you have and why is there no rust on your axle?
ORIGINAL: 07SCGT
