Whats the biggest engine?
RE: Whats the biggest engine?
ORIGINAL: acascianelli
Lycoming XR-7755
127 Liters
36 cylinder radial
5000hp @ 2600rpm
http://www.pilotfriend.com/aero_engines/aero_xr7755.htm
Lycoming XR-7755
127 Liters
36 cylinder radial
5000hp @ 2600rpm
There was an article in the most recent issue of 5.0, I recall, ofa guy that did the 427, and apparently it didn't require much, if any, relocation of things in the engine bay. If I had to go big-block, I'd go that route, and who knows, maybe by the time you'd want to do it someone may have a kit.
Bah... all you underachievers.
Here's what I'm swapping into my GT. I'm sure it'll fit fine as long as I don't have a strut bar.
Seriously though, check this thing out: 108,920 Hp and 5,608,312 ft/lbs at 102 RPM
http://people.bath.ac.uk/ccsshb/12cyl/
[IMG]local://upfiles/57675/30AB1498A3B540CAB63FCAC31408E048.jpg[/IMG]
[IMG]local://upfiles/57675/08D9567ACF0941CDBD2EF5CA372C24A5.jpg[/IMG]
[IMG]local://upfiles/57675/5B278BB10B8848BEAD997DB718C2DF67.jpg[/IMG]
ORIGINAL: kthulhu
Bahh that is nothing check this out lol:
http://www.conleyprecision.com/movie.mpg
[IMG]local://upfiles/60520/F3A9FF532DB747AB9117D264DFE29545.jpg[/IMG]
Why not put a $7000 514ci 600hp Ford Racing engine in? it equates to about 8.4 liters!! it has a compression ratio of 9.8:1 so it runs on pump gas, add 150 shots and be done!
You're gonna need a C6 transmission to handle that power.
Check out this link also:
www.mustangengines.com
And BTW...there are stroker kits for the Ford 460 not only to 514ci but to 557ci!!! 9 liters!!
