Are 20's a performance killer?
RE: Are 20's a performance killer?
ORIGINAL: Black06GT40324
rotating mass hurts . . . and it changes your gear ratio . . .
All depends on the wheels fitted. For example my friend lost 52lbs of weight on the wheels by changing from a 16" stock wheel adn tyre to a 17" wheel with semi slick tyres. Made quite a big difference and as rotating radius was identical speedo was spot on.
If you have chrome wheels chances are yes there hurting your performance. If you went with a light weight 20" set they could possibly be lighter than the stock 18's if you get some decent lightweight wheels.
I HATE 20's on s197's.... People say "they really set off the car" yeah well I just think they look horrible. The ONLY 20 acceptable is a chrome or black bullitt, but still not even close to worth it for the performance loss.
20's kill performance. You can feel it the first time you drive the car. I really like how they look and that makes it up for me. I also have a vert whcih is also a performance killer in the extra weight. Ride is stiffer, but car does handle better with smaller and stiffer bfg sidewalls.
the same can be said for a lighter wheel.
I myself was looking at some ultra light 18 and 19's which SHOULD weigh less then my stock 17's
www.tirerack.com has a nice set of ASA AR1's in 18' which look like the FR500 mustang wheels.
they weigh 23lb's per wheel on 18 x 8
|SIDEBAR| what do the Stock 17's on a GT weigh?
