viper 6 spd any feed back
RE: viper 6 spd any feed back
I have a friend with the D&D kit. His has the .50 6th gear. He cruises at 80mph at 1800rpm with 4.10's!
I do know he had issues with the flywheel bolts. He put his in last year and I believed he advised D&D of the issue and what the proper bolts he used were, so i'm sure they have resolved it by now.
ORIGINAL: nineinchnail1024
The T-56 is H-E-A-V-Y.
Actually, I looked on Tremec's site. They don't weigh too much more. I thought they would but apparently not. Our 3650's weigh in at about 120. The T56 is around 130. The new driveshaft alone will make up for the weight difference.
ordered the trans from d&d thanks for all the info I'll post results in twoweeks.It should be in end of next week It comes with trans bracket and drive shift. Now i need to figure out what gear to get 390 410 430 .
ORIGINAL: Timmay!!!
4.30s especially if your N/A.
ORIGINAL: BillyBobJoe
lol, might want to read his signature or at least his name next time. hint hint, procharger. I think 3.90s might be appropriate for a daily driver, otherwise the 4.10s should work well. nothing wrong with the 4.30s though. Find a gear/mph/rpm calculator and plug in the numbers to see which ratio you are comfortable with.
ORIGINAL: Timmay!!!
