BMR Rear Sway Bar
Old 07-19-2007, 11:50 AM
jdroth50
jdroth50's Avatar
Default BMR Rear Sway Bar
I just had my BMR Rear Sway Bar installed. It handles like a dream, but I hear a whole lot of squeaking coming from the rear end every time I go over the smallest bump. At the same time I had it installed, I had to re-install my original panhard bar, because one of the bushings on my BMR Adjustable had almost completely disintegrated. BMR is sending me the new bushings at no cost, at least.
My question is, do you think the squeaking is caused by the new sway bar or the original panhard bar? I don't hear the squeaking if I turn the wheel back and forth, so I don't think it's the rear-end trying to come un-centered. The squeaking only comes when the rear-end moves up/down.
jdroth50 is offline
Old 07-19-2007, 11:56 AM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: BMR Rear Sway Bar
My passengers side upper bushing sqeaks also. I am going to put some grease on it and reinstall the bolt to see of that helps.
howarmat is offline
Old 07-19-2007, 01:33 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
I get creaks and squeaks in the back as well. I think it's normal with aftermarket parts (or maybe it's just wishful thinking).
mAnYsTyLeS is offline
Old 07-19-2007, 03:40 PM
BlackBetty
BlackBetty's Avatar
When I installed mine, I only greased the bushings that go around the swaybar itself; I forgot to grease the bushings in the droplink-chassis connection. I just removed the bar, regreased everything, and re-installed. No more squeaks!
BlackBetty is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Gene K
10-21-2015 11:37 PM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
09-01-2015 08:16 PM
Quick Reply: BMR Rear Sway Bar
