Purchased the Saleen SC today!
RE: Purchased the Saleen SC today!
If you're sticking with the base kit and the stock pulley, I would use the stock airbox and MAF sensor. With the C&L intake you will need a custom tune and will also likely not fit under the stock hood. The C&L Racer MAY fit but likely will have clearance issues as well. What tune will you be using? Are you planning any further upgrades to the kit in the near future? I installed mine myself and can make you aware of some pitfalls in the installation and accessories/upgrades.
this is mine. im using the saleen tube, with steeda 90maf and intake. also i have cobra 39lb injectors and jdm vacuum lines. im using the 3.6 pullie with a gatorback. with the staoc set up, meaning stock injectors and stock intake set up i bairly made 400 rwhp ith a custom tune. it was sad, i was very upset. that was also with headers, midpipe, no cats, and cat back. after getting the injectors i made 422rwhp and then went with the 3.6 and i now make 452. i would recomend getting a new clucth and flywheel. one of my favorite upgrades i must say. i didnt do that when i had it installed and my first run at the track the tranny went boom, and the tow truck went down the road with my car on the back. i would also recomend some lca and uca. and last good tires. then youll hve a beast. i posted this video earlier but ill post it again. im the yellow mustang at the end. my first 05 was black, hence the name http://videos.streetfire.net/video/ac1d0364-0b3b-461e-8a96-994a0028f255.htm. all in all you will be vry happy once you get it done they way you want it. congrats and welcome to the world of f/i
ORIGINAL: drbobvs
ORIGINAL: drbobvs
