zex nitrous
RE: zex nitrous
ORIGINAL: WhiteStallion06
Longtubes , cai and tune if needed .
You need more air with the more power. to help the car breathe.
I have not done this but my mechanic swears a new TB is a must have with NOS and really helps. But i dont know.
RE: zex nitrous
ORIGINAL: Dex
You dont need more mods. Work on a nitrous kit first then try to improve it. 75 shot is a 75 shot
If I were to do it all over again, I would have got the plate system through NX. Much easier then drilling into your CAI.
RE: zex nitrous
ORIGINAL: craezjo
how much does it cost to refill a bottle or get a new one
I consider it fairly inexpensive. The more you use it, the more it'll cost you.
RE: zex nitrous
If you know the right person here in S.FLA you can get it at 2.50 a lb.But most places are 3.00 a lb. here.NO2 must be alot cheaper to get in FLA for some reason.....
ORIGINAL: Simon1
It is sold by the pound. It costs $4.50 a pound here. I've seen it down to $3 in some areas and as high as $5. 10 pound bottle (normal size) equals $45. I just filled mine the other day and it took 5 lbs. That was 5 passes at the strip, a few purges here and there, after loading the line and one sprint to show off for the wife.
ORIGINAL: craezjo
RE: zex nitrous
Most of theloacally shops that do any type of machine work or racing type componets will have it. Whenyou drive by the store, they will have signs indicating they do refills. It's a good idea to call ahead of time and make sure they have N20 as they run out sometimes and also someone to do it.
Prior to bringing your bottle in, put it in the freezer over night or until it's super cold. Filling the bottle creates alot of heat. The colder the bottle is prior to filling, the easier it is for the person to get it filled completely. The stores here won't even try to fill them if the bottle iswarm or not frozen. They tell you to come back tomorrow with a cold bottle or leave it there to put in their freezer.
