Can Someone PLEASE help me?
After disconnecting my battery and trying to put it back I came across these two triangle pieces of metal that form a square that goes below a nut to hold it in place. It is located beside the battery cable connection on the positive cable (red cover). The other sode does not have this extra screw.
When I try to screw the nut down it is forcing the two apart so they wont stay together.
I have tried putting a screwdriver to hold the pieces in place when I screw the nut down but when I tighten they are forced apart eventually.
What do I need to do?
Is this piece needed or can I toss it?
I can tell it holds the nut to the proper height but I dont know if it is nessasary.
I can tighten it enough so they are out of place and it holds... but the metal of the square formed touches the metal on the battery cable.
I had it like this and when I drove to work the radio started to scan on its own for a minute.. which worried me.
Also I am worried it might eventually work loose and the nut will come loose and I'll be in trouble.
What do I need to do or how can I get it to fit and stay as I screw down?
