Hurst Shifter problem?
RE: Hurst Shifter problem?
My Hurst was stiff after installation but it did loosen up over time. As said by others it has a notchy feel that makes shifting positive and precise. And the look is perfect for the retro styling of the vehicle. But everybody is different andI guess it comes down to personal taste.
I am not blaming technique but the Hurst does need to go from 1st to 2nd with a straight back motion, no sideways pressure to catch the gate. 2nd to 3rd is smooth as silk, it just finds it like there are no other choices. Keep it about a month and see if it doesn't get better. The only gear that's a liitle hard to find is reverse but that's ok with me.
ORIGINAL: beefrits
My hurst is the same way and i've had it in for over a year. I do love it though i have never missed a shift from 1-2 or 2-3. I like the notchy feel to it and don't have any trouble banging through the gears. One thing to make sure that was installed correctly is the link at the bottom of the shifter it has to go a certain way. Check this link out. What i'm talking about is step 23
http://www.fordmuscle.com/archives/2...ter/index2.php
The Hurst shifter is very "positive feeling" but this is a good thing. It does seem to prefer straight front to back motion. It is harder to push/pull than stock but should not be unpleasant. I like mine. Did I read your 2nd post right in that you installed a new clutch and flywheel at the same time as the shifter? Could this have something to do with the shifter difficulty? (I don't know how it would.)
Slight thread hijack: What clutch/flywheel combination did you get? Do you like it. Thanks.
Sleeper2
Sleeper2
I don't think it has anything to do with the new clutch it goes into gear fine it just take a little more effort than I was expecting. I will have it looked at tomorrow. As for the clutch/flywheel it is a Spec's 2+ clutch with the aluminum flywheel. Its only a little stiffer than stock, but so far I am happy with it here is a link to the site I brought it from.
Clutch: http://www.lmperformance.com/6228/73.html
Flywheel: http://www.lmperformance.com/5856/73.htmlno pic
This combo is rated up to 520ft torque
If you go with this combo be sure to have in balanced together.
