Lethal Performance FPDM Wire Upgrade Kits Available Now!
We're glad to now offer our infamous FPDM wire upgrade kit for the 05+ Mustangs.
Lethal Performance 05-08 Mustang GT FPDM Wiring Upgrade Kit [LP-05FPDMREWIRE] - $45.00 Want to get the best performance from your fuel system? Well now you can with our infamous FPDM wire upgrade kit only from Lethal Performance. The Lethal Performance FPDM wire upgrade kit is the easiest and best way to help lower duty cycles and allow your fuel pumps and fuel pump driver module to run more efficiently. By installing this kit you'll give a more constant flow of power to the Fuel Pump Driver module. A better flow of current and no drop in voltage when the system is being pushed will keep the system running 100%. It's been proven time and time again when providing the FPDM with a better flow of power duty cycles can be dropped by 10%. All this for $45 and a a simple 45 minute installation. Detailed Instructions Available in our Technical Documents Section FPDM Wiring Upgrade Kit Features: * 17’ of 8 gauge power wire * 1 AGU fuse holder * 1 40 amp agu fuse * 4’ of Wire loom * 10 Zip ties * 2 14-16 butt connectors * 2 10-12 butt connectors * 1 8 awg butt connector * 1 40 amp relay * 1 relay socket * Misc heat shrink * 2 8 awg ring terminals GOLD Lethal Performance 05-08 Mustang GT FPDM Wiring Upgrade Kit [LP-05FPDMREWIRE] - $45.00 http://www.lethalperformance.com/cac...REWIRE_LRG.jpg[/align] |
RE: Lethal Performance FPDM Wire Upgrade Kits Available Now!
so, is this kit for use with any pump we use, or is it pump and h.p specific. for example. someone who s/c'ed thier car and stock pump is unable to build pressure fast enough when it get in the upper rpm range,but they are fine at 430 rwhp. \
also what if a shop made a tree for a second focus pump, could this be used. on both, or would you need to. and last, is this the same thing as buying a bigger gauged wire and unning it to the pump to get more amperage constantly running to it, and so it doesnt lose vloltage when you turn the a/c on and decide to go wot thank you tom |
either way, it isa a good deal. i would buy one if i needed it. ill keep it in mind
ORIGINAL: blackhorse05 so, is this kit for use with any pump we use, or is it pump and h.p specific. for example. someone who s/c'ed thier car and stock pump is unable to build pressure fast enough when it get in the upper rpm range,but they are fine at 430 rwhp. \ also what if a shop made a tree for a second focus pump, could this be used. on both, or would you need to. and last, is this the same thing as buying a bigger gauged wire and unning it to the pump to get more amperage constantly running to it, and so it doesnt lose vloltage when you turn the a/c on and decide to go wot thank you tom This wire kit is not pump specific. Whether you have a single pump or piggybacked an additional pump it's still installed and used in the same fashion and is very effective. In regards to the second part of your question in just running a bigger wire directly to the pumps this works in a different way. By upgrading wires to the pumps you will indeed be giving the actual pumps a better power supply however our wire kit in essence not only does that but also supplies the pump driver module with the proper constant voltage needed to run the pumps efficiently. Our kit is fused as well as uses a triggered relay to properly get the right amount of constant power to both the FPDM and the pump/pumps. It's been done for years now on the 03-04 Cobra's and is very effective. Hope that helps. Jared |
