Xcalibrator 1 for Kenne Bell SC
Old 08-26-2007, 12:24 AM
black stang
black stang's Avatar
Default Xcalibrator 1 for Kenne Bell SC
Hello All,
I have an XCalibrator programmer provided by Kenne Bell with Factory, P1 (8PSI) andP2 (10PSI) tune programs.
I was thinking on moving forward with a LiveWire or XCalibrator 2 in order to have more info, code reading and cleanning, etc.
Is there anyone overthere that knows if it is possible to migrate in some way through a PC or something the current programs on my XCalibrator and transfer them to an XCalibrator2 or LiveWire?
Beside the above, I am insterested on backing up the current programs just in case, we never know... any ideas?
Best Regards.
black stang is offline
Old 08-26-2007, 12:58 AM
hammeron
hammeron's Avatar
Default RE: Xcalibrator 1 for Kenne Bell SC
i do not believe you can transfer (upload) atune(s) from
your SCT Xcal2 device, to a PC. You can only download
tune(s) from the PC to the device.
hammeron is offline
Old 08-26-2007, 09:55 AM
Meangreen1200
Meangreen1200's Avatar
ORIGINAL: black stang
Hello All,
Best Regards.
I think that the only difference in the KB tune is the spark advance, The PSI in changed by the pully size not the tune.
Meangreen1200 is offline
Old 08-26-2007, 11:05 AM
black stang
ORIGINAL: Meangreen1200
Thank you, I agree with you about the PSI directly related to the pulley change.
As I said, I am really interested on determine if there is a way to back up the current xcalibrator programs, or a way to transfer them to a newer Xcalibrator tool with code readings, etc.
Best Regards.
Old 08-26-2007, 02:57 PM
howarmat
s197 Junkie
howarmat's Avatar
You really should have that dyno tuned to get the most out of the KB.....it would be safer too. You can then have that tune loaded on the XCal2 for you also.
howarmat is offline
Old 08-26-2007, 08:39 PM
ziperhead
ziperhead's Avatar
I just loaded the KB tune via the supplied xcal1 and also have similar thoughts. I have a xcal2 and was wondering ifI can alter the tune loaded to the car via the xcal 1 using my xcal 2 by hooking up the xcal 2 to my car and adjusting the paramters? My thought would be that the xcal 2 would load the KB tune xcal 1 tune as the new stock tune on the xcal 2.
Have not been brave enought to try it. Just a thought
ziperhead is offline
Old 08-27-2007, 11:22 AM
Justin00Stang
Justin00Stang's Avatar
You'll need to get a new custom tune for your KB setup, if you geta LW or X2. The files can not be pulled off the X1.
Justin00Stang is offline
Old 08-27-2007, 02:47 PM
DROCKOFTX
DROCKOFTX's Avatar
I was thinking the same. I know Diablo saves the original backup when you first use it. Why would this be any different if you already have a new tune loaded into the PCM?
DROCKOFTX is offline
Old 08-27-2007, 02:56 PM
hammeron
hammeron's Avatar
it wouldn't be any different.
if you use an Xcal2 to save the
pcm tune (stock or custom doesn't matter) it will be saved, but
you still won't be able to MOVE that tune from the device to
a pc.....
hammeron is offline
Old 08-27-2007, 03:50 PM
howarmat
s197 Junkie
howarmat's Avatar
ORIGINAL: hammeron
a pc.....
Diablo would allow for this, but SCT doesnt allow users to save tunes to a PC from the device
howarmat is offline
p51pony
12-02-2015 10:02 PM
MasterLanMan
09-26-2015 10:03 AM
hookergt
09-04-2015 06:57 AM
DOHC330MustanGT
09-13-2004 02:54 PM
98stang
11-12-2003 09:56 PM
Quick Reply: Xcalibrator 1 for Kenne Bell SC
