Slickest gear oil?
Slickest gear oil?
After having the 3.73's installed, my limited slip diff started squealing again during slow turns. What is the best differential oil and friction modifier known to mankind that will end this? Just want to make sure because changing this is not easy, and the stealership probably won't cover it since I had the gears changed.
RE: Slickest gear oil?
Tufoil is the best lubicant out there. You have to order it at Tufoil.com. You don't have to use a whole pint. I add it to my regular oil after a oil change. I think they have gear lubricant as well.
musnicki
09-23-2015 07:11 AM
