UDP Installed - Finally
RE: UDP Installed - Finally
19. After the pulley seats up against the crank snout (tool will bottom out), unscrew the tool and replace with the new Ford crank bolt. Re-using your original bolt is not recommended, but that's your call.
Follow Ford’s recommended torque sequence:
Step 1) torque to 66 lb-ft
Step 2) loosen bolt 1 full turn
Step 3) torque to 37 lb-ft
Step 4) tighten bolt an additional 90 degrees
