basic saleen s/c ???
who has some dyno numbers for the basic saleen kit. i believe it is 435hp/420tq at thecrank so i am guessing about 340hp at the wheels. but i hear someone had theirs dynod and only had 303hp. it was a hot day but 303 is way off from 340. so am i going to be disappointed??????
i may go to the upgrade kit for 475hp but i should see around 375hp and if its not going to be close i may be unhappy and i dont want to be unhappy????
RE: basic saleen s/c ???
i think the 4" pulley kit doesn't require new injectors cause its supposed that the kit will get the car to 400 crank hp and thats the limit of the 24lb injectors we have? i think i've read it somewhere.
I'm running at 19 timing, so it's conservative. According to brenspeed the numbers are right on, also according to saleen tech support my numbers are higher then their stock pully numbers so they said they should be right on.
I have the 3.4 pully, belt, spark plugs, and Gt dual fuel pumps on the way and will be installed and dyno'd probably Friday morning. I will share the results.
ORIGINAL: sactown
I was just curious because it seemed a little low, I am making 429rwhp with a 3.8pulley, but I do have some additional mods.
The only real way would be for both of us to take our cars to the same dyno. Are you near South Carolina I noticed that most people hitting the 420 mark on the 3.6 pulley has had fuel pumps and/ or spark plugs installed. Could that make this big of a difference?
