very random but good trick
RE: very random but good trick
I don't have time to do the searching, but there was a good thread on this a few months ago.
When downshifting, it creates a vacumn (duh, that's how it slows you down), and I guess that's not so good for the valves.
I do it anyway...
I do it anyway...
ORIGINAL: 05RedHead
I do it anyway...
I do it anyway...
ORIGINAL: UberHax0r
[/quote]
+1 I have a vacuum/boost gauge and letting off the gas quickly creates more vacuum than downshifting. Downshifting actually lessens the amount ofvacuum because the revs increase. The engine always has a vacuum except when the trottle is fully open. There's 23psi of vacuum at idle with my car. Psi, is that the correct term?
I downshift everywhere, but I don't do it so much as to not need the brakes.
ORIGINAL: luckydawg003
At what rpms do you guys usually change gears? I change at 2500 rpms. But everytime I change gears my car like clunks. It is never a smooth shift. Always jerks my head back too or my wifes head when she rides with me. Sometimes when I shift I put in the clutch then give it some gas and then slowly release the clutch like 3-5 seconds and it still is rough and not smooth. Am I doing it wrong or is it just the way the mustangs are.
try letting go of the clutch in a "smooth" like matter first, then give it some gas. when you rev up 1st before letting go of the clutch it cuz that head jerk ur having, it sucks.
so remeber, let go of the clutch, then give it gas while shifting.
ooo, and as fair as downshifting to pass someone, i rev match...YOU CAN FEEL HOW MUCH BETTER IT IS. and i only ds to slowdown when im in the "show" off mood...
ORIGINAL: lldsandsll
i'm not disagreeing, but i'd like to see the article that explains why downshifting is detrimentle
Besides, the brakes are there to slow the car down, so using the engine to slow the car is, in a way, like not using the right tool for the job.
Google downshifting technique and you'll find some good articles on it -
the only time i downshift to help slowdown is if im driving a tow vehicle on a steep grade, or if im really haulin *** and need the trans to help,............. or if its dark out and i dont want the cop whose up ahead while i was speeding to see my brakelights[sm=nono.gif]
when im coming to a stoplight, usually i pop it into neutral and coast to the stop sign....only downshift on approach to a freeway standstill.....and my car jumps when i switch gears too...i thought it was just my driving...nice to know im not the only one...i thought i just needed to get used to my car!
