Need intake advice
Need intake advice
Ok.. I'm looking to get a C&L CAI/SCT2 from Brenspeed. What I would like to know is this: On an otherwise BONE STOCK 06 MT vert, should I get the regular C&L CAI or the C&L racer?
These are what I have chosen at this point, please no long diatribes about something else that's better.. With ONE exception - I'm planning to put a Saleen Series VI on it early next year.. If the C&L won't fit, then what will?
Thank you in advance for all the informative responses, you guys are great!!
RE: Need intake advice
Brenspeed sells the steeda intake with the SC, I have heard of clearance issue's when using an intake such as the C&L, other than that the racer I believe is cheaper but cannot be run w/o a tune while the street version can. I also believe although not positive that the racer intake tube is a larger diameter than the street. Good luck with your decision I'm sure you'll be happy with whichever one you pick.
I plan on getting the SCT with whichever one I pick. And before anyone tells me to get a predator, JDM uses the SCT, so that's the one I'm after, in keeping with my Saleen plans.
So, knowing that I plan to get the tuner, can I run the C&L racer with the Saleen, or should I get the Steeda/SCT due to fitment issues?
Thanks!!
Thanks!!
Since you are going to need a tuner for your SC down the road, have you considered just buying the SCT tuner now with three tunes from Brenspeed? Adding a CAI makes a marginal difference. The majority of power on a NA motor comes from the tune. Plus, the tune will improve the drive-by-wire response.
I called Brenspeed this morning and spoke with Seth. He said the only CAI that fits the Saleen Series VI is the Steeda, so I have one of those and an SCT on the way with 87, 91 and 93 tunes. Should be here Friday. I can't wait!!!
ORIGINAL: JMono
ORIGINAL: exx1976
Luke9222
10-22-2015 11:55 PM
panic
09-10-2015 05:56 PM
