I hope 6 quarts was right
#41
RE: I hope 6 quarts was right
[blockquote]quote:
ORIGINAL: mcburns36Anaccidental overfilling oil into your engine can cause problems . As the crankshaft rotates it will churn the oil, causing aeration and eventually sustained foam may form. This can lead to overheated motor oil, oxidation and a loss of oil pressure. Spongy aerated oil is hard to pump. It starves the engine and critical lubricated surfaces.
[/blockquote]
[blockquote]quote:
the oil will kind of lather up and you'll be pulling oil plus air through the oil passages. Which can lead to oxidation.
[/blockquote]
yep.
Double Yep
[/blockquote]
[blockquote]quote:
[/blockquote]
yep.
Double Yep
#42
Has anybody with the STS turbo changed their oil and noticed how much extra it takes to make it full? There are oil lines running front to back, back to front. I would assume another quart will be sufficent but trial and error will give the final answer. I'm sure the installer will know. But if anyone else does I would appritiate it.
#43
ORIGINAL: mcburns36
[blockquote]quote:
[/blockquote]
[blockquote]quote:
[/blockquote]
yep.
Double Yep
[blockquote]quote:
[/blockquote]
[blockquote]quote:
[/blockquote]
yep.
Double Yep
I'll give you a lesson.
put [ q u o t e ] before the quote and [/ q u ot e ] after it. Don't use spaces. I just used spaces so it wouldn't actually do it
doesn't this look much better you n00b?
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
breaking
10-02-2015 01:27 PM
DreadPirateRoberts
09-26-2015 02:11 PM
